Re: 15ph 1989 Force with a dead cylinder
Plugged exaust ports.<br />If it has spark on the dead cylinder,then it is not sparking at the proper time, or that cylinder is not getting fuel.No fuel on finger, this is possable. This could be due to low compression,which isn't drawing-in fuel.Except, that it kicks the finger off the hole. It could be reeds gummed with carbon or varnished-shut.But I still supect exaust-side is plugged with black goo.<br /><br />Try a can of de-carbon cleaner. (that is, if you can get the engine to run on one lung).<br />Try the compression test again. Check exaust side for plugged ports (carbon).These baby Forces were notorious for plugging thier own exaust ports with carbon.<br /><br />------------------<br />I'm no expert, but I DID sleep at a Holiday Inn last night!
