Re: force tilt pump diagram
j bossman, sorry,the springs go in the brush holder first then the brush. take a few strands of fine wire{strip from a piece of 14,12 or 10ga wire } and put over the end of the brush,then take the wire ends to the outside edge of the cap and bend the wires up over the top of the cap.do this to both brushes. the ball bearing goes on the top of the armature shaft,use a little grease to hold it in place. put the armature into the res. then the motor frame , then lower the cap down onto the motor.get the brushes started on armature leaving enough room to pull out the wires. once the wires are removed you can bolt it together. keep the seals/o-rings in place while doing this. hope this helps you out
