Just rebuilt '90 Force 150 ,new pistons, cylinders rebored etc... Everything back together fine no Issues. Trying to set<br />timing , ran into issues.<br /><br />Manual (Force 150 hp Service Manual- Brunswick marine - OB4643) say to set cranking timing to 30degs, WOT at 32degs.<br /><br />Not even close, cranking is retarded almost to TDC mark. This allows good rpms 750 at idle, 32 degs at WOT.<br /><br />Engine runs fine at these settings.<br />Timing adjustment seems fairly centered (not maxed out in or out).<br /><br />Am I missing something? Or is the manual that far off.<br /><br />Thanks<br /><br />Am I missing something or is
