I have a 96 Force 90hp that the overheat alarm went off this weekend on the lake. The motor hadn't run over 10 minutes when the alarm sounded...first time this had ever happened. We were going to do some trolling and hadn't even accelerated to quarter power since launching. I immediatlly shut her down and then tried a restart and it started right back up and no alarm...I checked the engine and it was not hot and water was coming out of the pee hole. Accelerated to full throttle and she ran smooth and to normal speed and rpm. Decided it was a fluke so went back to trolling station and 5 minutes later the alarm sounds again. Shut down and restart and no alarm but decided to take her out of the water and back home. Removed the lower unit and the impeller was perfect condition. Put back together and ran on earmuffs for 5 minutes at idle and water is coming out of the pee hole and the prop exhaust and no overheat alarm. Pulled the thermostat and it looked ok but would have replaced it if my dealer had been open and had part.<br /><br />Does anyone have any idea what could have caused the alarm?
