• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Lower Unit Oil??
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Lower Unit Oil??
    I had a question regarding regarding Lower Units. I have a 1975 55 HP Chrysler. To my knowledge the lower unit oil has never been changed. When I change this oil should I expect and problems? Will it be real thick or thin? I'm just trying to anticipate any problems before I take out the screws. Any advice? I've heard the lower units be compared to the rear end of a car. Is this a correct illustration? Is the oil in the lower unit similar to the oil that would be in the differential? I'm just trying to get a better idea at how all of this works. I'm still quite the novice Thanks,Shane
    Re: Lower Unit Oil??
    It should be just like the gear oil in a rear end. Remove the drain plug and also the vent plug.If it has been sitting for more than a week or two, you might see a few drops of water come out first. More than a few drops of water can indicate need for attention. Like seals replacement. If rusty water comes out that is bad. It is usually suggested here to replace the washers on the plugs as they sometimes leak water in if they don't seal well upon reassembly.I usualy use a good grade 80-90wt gear oil and buy a couple of quarts. With two quarts on hand I can cut the tip off one bottle and push it into the lower drain hole. Then squeeze till you can't squeeze any more. Now remove the bottle while putting your finger on the hole while your assistant refills the bottle from the second quart. Then squeeze in some more till it runs out the top vent hole.
    • #3
      There are 2 key indicators when replacing lower unit oil : If it is grey in color you have water in the system, the next is to check for small particals of metal, which indicates some gear mesh problems. You should be changing the lower unit lube at least 1 time per season.
      • #4
        SHANE, I bought a little gadget that makes the job a little easier with less mess. One end replaces the cap on your bottle of gear oil and has a "finger pump" similar to a bottle of hand soap. A short hose connects to a fitting which is threaded to fit the bottom hole. Remember to remove the top plug after you get the fitting tight and you're in business. To add a 2nd bottle, just switch the pump to the new bottle and continue. A good investment for about 5 bucks at Walmart or K-mart. Have a great day. -G.
        • #5
          It is alot like a car rear axle meaning hypoid. I would not use an automotive lube in them though. Use a marine 80 to 90 weight gear lube.
          • #6
            Their are three API service categories for gear oils.API-GL1, API-GL4, API-GL5.Most outboard manufactures recommend API-GL5 gear oil for their lower units. API-GL5 gear lubricants are for both mechanical shift units calling for type B gear oil and electrical shift mechanisms calling for type C gear oil (only the viscosity value will be different for each application)
            • #7
              I KNOW ONE THING IF THE LUBE COME OUT LET'SSAY NOT THE BEST I WOULD CHANGE THE LUBEEACH TIME FOR ABOUT 3 RUNS. THEN IF IT LOOKSBAD LIKE MILK THEN YOU KNOW YOU GOT BAD SEALI KNOW TRENT AND I DO NOT AGREE ON THIS BUTYOU COULD SPRAY THE SEAL DOWN WITH BRAKEFUILD TO SOFTING THEM UP. IF THEY GET A SOFTTHEY MIGHT START TO SEAL FOR YOU.BUT CHANGE THE LUBE EVERY TIME FOR THE FIRST2 OR 3 BEFORE IT COST YOU ABOUT $300.00TO WORK ON THE LOWER UNIT.I HOPE YOUR NOT MAD TRENT.GOOD LUCKREX A HUBBLE
              • #8
                Rex.. Iv never been mad at you. I just disagreed with you on the brake fluid thing.. If it works for you, go for it!! But I will just replace the seals. But what the heck do I know
