Good evening,
So as i stated i have an Chrysler 135 outboard that is giving me some ignition trouble. So, on the back of my ignition switch there are these letters. A M M B C S
My diagram shows that "B" is that battery, C is choke, A isn't listed, one of the M's goes to the TACH terminal, S for starter solenoid, So does the ignition go to the A terminal?
I have hooked up to what i thought was correct and the only thing that works is the auto choke...So i got that going for me.
I was hoping someone would tell me what the hell I have been doing wrong and how to fix my issue.
Secondly, Can someone tell me how I can hot wire this or wire up a push button type ignition? i
Any help would be greatly appreciated.
Thank you
Thank you
