Hi all. I was wondering if anyone can pinpoint where the issues might be.
The engine will not crank fast enough for it to start. I have brand new battery. When I remove the spark plugs it cranks over no problem. With the spark plugs in the starter barely cranks over and stops at compression point. I will try to attach a video. Maybe this will help.
Slow to crank over (plugs in)
https://1drv.ms/v/s!AiqvEVe5xKCr3h2cgiEfKh1EoIhN
Fast to crank over (plugs out)
https://1drv.ms/v/s!AiqvEVe5xKCr3h6Gx05kTRQqDFZ4
