1985 Force 85hp outboard
I have replaced all the fuel lines, installed water separator fuel filter and rebuilt all 3 carbs. Motor seems to run fine. Boat is me to me but I think it is not getting as much power as it should. 28-30mph.
I replaced all 3 surface gap spark plugs but
The #2 spark plug looks like it was just taken out of the box. The other two appear as you would expect them to.
Pulled off the #2 plug wire and I do have spark but does not seem as bright and powerful as the others...
Do I have a bad plug wire/coil ??? Can I swap them around and see if I get the #2 plug to look like it was firing???
PLEASE any ideas, I am very new to this but am learning allot.
Help
Help
