I can usually only get on here in the early AM.
I still don't understand the "bearing" that you replaced?
Add a couple of pics?
You can use a photo sharing site until you get enough posts.
I think it's 3 or 5 posts needed to add pics.
The operation, you pull the cord and it in turn throws the locks or "starter pulley retainer
F681592" into the gear on the top of the flywheel.
That catches and the shaft turns.
If they are over lubed?? they can stick.
Usually no lube is needed.
