Jonathan Anderson
- Sep 30, 2017
- 9
I have noticed as of late that while my Outboard motor is running, the voltmeter I installed in my dash has slowly been dropping and rising while at idle. I hooked up the volt meter to the wire coming from the stator to see what the output was reading. Its going from 11.8 up to 14.23.... Pictures are shown in the links. I am guessing that this would mean i need to replace the stator, I dont see why the volts would change so rapidly. Anyone with any experience with this issue, i would be very grateful for some input or maybe an attack plan. Thank You.
https://ibb.co/bZUXSb
https://ibb.co/fZTgLw
https://ibb.co/jqge7b
https://ibb.co/eHbOYG
https://ibb.co/kCPctG
https://ibb.co/cQtgLw
