Why are half the connecting rods painted?
jerryjerry05
Maybe?? they are put into a machine to break the end off and they might have to go in that machine a certain way?
jimmbo
“?Why are half of the Connecting Rods painted?”?
Are you asking why 2 out 4 connecting rods are painted? Or, are you asking why half of each con rod is painted?
rk970
Ok. Why is the lower half of each connecting rod painted. The piston pin half has no paint on it.
jimmbo
Maybe Chrysler was having problems with the rods cracking in that area and painting the area with a light colour might show oil stained cracks better upon an inspection or overhaul, without resorting to Magnafluxing. Just a wild guess, I'm sure someone will blow that theory out of the water quick
