Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Adding a trim gauge and sending unit on a Force outboard
  • Adding a trim gauge and sending unit on a Force outboard
    Recently purchased a pontoon boat with a Force 90 (Mercury Marine) does anybody know of a aftermarket trim sending unit & gauge that would work with this motor. Any help would be greatly appreciated.
    Need more info??
    Year? Model?
    The newer 93-99 is Mercury and parts shouldn't be hard to find.
    The older is Force and those parts are a lot harder to find.
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
    88 Bayliner 21CC 2001 Mercury 225 HP EFI
    • #3
      OK, the problem I have is that the ID tag on the motor is badly worn. So to know the Year, Model or Serial # is questionable. It is a Force Motor.
      • #4
        ignition is cdm modules, which were used from 1996 through 1999, so all parts were from the Mercury/Force era.
        Medford, WI
        • #5
          Mercury bought Force in the early 90's By 95 they were using Mercury's parts.
          Before then they used some Mercury and some Force.
          ​Like Roscoe said that's a Force with Mercury parts.
          ​Contact Mercury Service for the parts???
          ​Post on here what you find.
          ​Good luck.
