i have an 85 force 125. ive done a bit of work, and am close to done? i replaced the old fuel pump with a used one. to test it i took the fuel line off, gas pumped out, but not a ton. i placed my finger gently over the fuel like, and it sprayed everywhere. i want the fuel pump of my list before i finish the carbs and put them back on. does this engine have a high pressure, low delivery system? it seems that at least something is working right in relation to the fuel pump. is this what i should expect from this fuel pump? im guessing so, but i dont want to revisit the issue. i tried to look this up in search, but only found how to fix these pumps, not how they should preform. thanks.
