auro2tango
- Aug 19, 2017
- 12
First time poster, but long time reader. There hasn't been one issue with my outboard I haven't been able to troubleshoot and repair with the wonderful information on this site. But sadly I have to ask a technical question. The Engine is 1994 Force 50hp 2 stroke, 0E081281. Started giving me some very nerve-racking troubles last night. in a neutral idle I can't get it to stay idled under 2000 rpms and it makes this random jerking with a clunk ( Honestly, it sounds like she's trying to shift into gear is the best way I can describe it). When I do put her into gear the rpms drop (as expected) but the jerk and clunk are still there. The clunk and jerk are in all gears (F N R) Anything under 2000 it will idle very rough then die and in gear, you can forget about it, I assume under a load she would just die even quicker. I checked my static timing at WOT, it's right on, Changed the spark plugs and wires, double checked all electrical connections, played with the idle mixture on the carb and idle control screw on the tower. Compression is great, and starting fluid around the powerhead and carb reveal no leaks. I haven't taken apart the lower unit yet, but I like to work from the top-down and I have run out of ideas.
