pita482
- Jun 28, 2010
- 92
Anybody familiar with the internals on a 150 block, the lower crank bearing has a hole for the bearing locate pin but the block has no locate pin in the lower journal, it's just a smooth journal, I know the crank is held in position by the upper bearing, just thought it was odd that the bottom bearing journal with the seal had no locate pin, guess it's held in position by torquing the block?
