redneckyachtclubebbtide
- Aug 9, 2017
- 3
i've come here for help because i believe in y'all. i removed my lower end to do the water pump impeller and now gears wont shift out of forward. had it in neutral during removal but have since read that you're supposed to put it in forward. now clicking sound when turn prop by hand. shift rod can be rotated about 270 degrees when rotate prop a little to help, but doesn't do any shifting...remains in forward. think i messed something up with the cam in the bottom and am desperate for advise if this can be corrected without taking all gears out and performing surgery???
