ggundersen3
- Dec 25, 2007
- 246
I bought a 1994 Bayliner 185 Capri with a Force 12 OB in excellent condition in 2014 for a great price knowing the trim and tilt didn't work. I've used it without the trim and tilt since but am finally getting around to wanting to repair it. It appears all that is really wrong is the hydraulic lines were disconnected for some reason, maybe got damaged and messed up, in fact 3 out of 4 are missing. I can hear the pump running fine off the switch on the throttle. I see other posts that say the replacement hydraulic lines are no longer available but there are some on Ebay I could buy and use. I also heard that OB motor had as many as 4 different trim/tilt systems in 1994. I'm looking for advice/insight on repairing this. What do I do for a practical approach to repair this?
