CApTaInGoOfy
- Aug 17, 2015
- 91
So I removed the lower because I noticed at the ramp that I had no water flow from the tell tale or the back area. Ordered a new water pump kit FK 1073 as my water pump body was pitted and the white plastic in the body around the drive shaft was chipped up. The impeller was chewed up on the top like it was binding on the body. So removed the lower and removed the driveshaft from the lower. Unscrewed the shift rod completely out of the lower but now I can't seem to get the darn thing to screw back in. I can get it into the lower but for the life of me I can't get it to thread into wherever it's supposed to thread into.
My question is does anyone have any tips/tricks on getting this to thread onto whatever it's supposed to thread onto. Or do I need to separate the lower unit to be able to thread this shift rod into whatever it threads into.
