I'm working on a 1989 force 125 hp. I have static timing at 28 degrees wot. The issue (maby) is when I back off the throttle a fraction the trigger actually moves further advanced then wot. It's like it goes to full advance then comes back a degree or 2 at wot. I have not tested the static timing at this point a hair before wot but I would imagine it will be close to 30 degrees static?. You can also feel about 100 rpm's on the water just bringing the throttle back a hair in this area. Link and sinc otherwise is spot on. The space between the threads is about 1/2" on the timing link. My question is the timing linear to full throttle or does it retard slightly at full wot due to the linkage? I may be able to post a video if I'm not explaining well.
