pantaloonz
- Nov 28, 2014
- 237
Hi All
First boat summary: 1986 Bayliner Capri 125 HP force 1254X6B
So my splashdown was "mostly" successful. I got water bleeding in from somewhere.. not enough to scuttle her or anything but there is some water in there
It started easily, but was dying going into gear, so I popped the top (I brought out tools) .. .. reset the idle mix again (1 and 3/4) is where I landed.
I then turned the idle up just a little bit to get it to stop stalling coming into gear.
That fixed the starting issue, and the stalling issue. It will go well enough to 1/2 throttle. After that it goes into what I'm calling a sine wave revving.
Vrrrrrr-RRRRRR-rrrrrrr---RRRRRRR--rrrrrr--RRRRRR it does this for about 5 - 15 seconds, then will eventually catch and immediately rev up, hold, plane out, and then I can cruise pleasantly, any back off of the throttle and the exact same thing happens, when trying to throttle up. It's quite repeatable.
Thinking maybe fuel pump? - it does sound to me like some sort of fuel problem
Whether I throttle up slow, or throttle hard, it will struggle each time at 3/4 - WOT and make this funny inconsistent rev.
In Franks sticky he mentioned "sagging, then recovering, then catching" and suggests the mix is too lean, this is the behavior I'm seeing except that the sagging/recovering repeats itself multiple times before catching on and going (maybe that is exactly what's happening?).. could this still be a air mix issue?
Thanks!
-Devon
Thanks!
-Devon
