My start battery will not charge while motor is running.
I've checked the rectifier/regulator and I believe it's good. I ohmed between the red wire and the other 3 and got a reading, then reversed my leads and got no readings and from what I've read, it's good. Besides, I did replace it and it will won't charge the battery.
I disconnected the 2 yellow wires from the stator each one to ground shows no short. Across the yellow wires, I got something like 1 or .1 ohms.
I checked for continuity between the + lead on the battery to the starter and it showed continuity. I checked from the - lead on the battery to the motors ground and it showed continuity.
I don't know how to check any further. Can someone help?
My engines model number is H090412NX, Serial number 0E010171.
Thanks,
Nathan
Thanks,
Nathan
