120 HP 1997 Force Water Pump problem?
Medic814
I replaced the Impeller on my 120 HP Force motor and it is releasing water out of the tell tale fine. The motor is also running well. I just noticed with the ear muffs on in the driveway it appears to be leaking water from what I believe engages the propeller. Thanks in advance for any advise. I'm just not sure if this is a problem or not. For some reason it will not allow me to upload a picture. The place I am speaking of is at the front of the lower unit toward the boat.
