This motor will idle fine. But usually it takes a long time for it to slow to a reasonable idle. Even when running in nuetral going fron fast idle to normal idle it takes a long time before it finally winds down. I have checked all the cable linkage and it seems to be ok. Wondering if the feul pump diagram could be leaking and takes a while to burn up the fuel buildup in the crankcase. Have you ever heard of that? Other suggestions?
