At the risk of stating the obvious but are you starting with a fully charged battery and is your starter working well? I ask because these motors will not even think about starting unless a certain RPM is hit. They will not kinda lump over like a car motor will. Also, I'd avoid starter fluid in a 2 stroke. It strips off all the internal lubrication and can damage the motor. I use some pre-mix in a spray bottle.
