. Was this recently? I've struck out so far.I eventually found one on EBay after looking for a long time.
Hi,
Not sure I can help locate the part. I found a Force NLA on eBay.
I want to comment on the idle smoke. I have a small Force that has only one mixture screw adjustment (low cost carburetor). I have to find the right balance between low and high speed. I make the trade-off to the high speed end. I rarely idle the engine. Consequently, my idle smokes a little and coughs every now and then. It hasn't hurt anything unless the flywheel is not tied down tight enough and the key shears at a cough.
I guess I'm not sure the two are related. Any chance that the local tried a tune-up as part of his work?
Just thoughts,
J
Tried reading really slow and I've come to the carburetor. Indeed, the exhaust is not choking you out. There is too mush fuel trying to burn so we smoke blue and stall, cylinder flooding. When you stall it, check your spark plugs right away to see if they're wet. be careful, they'll be hot. If so, flooding. When the cowl is taken off, more air creates the proper fuel / air ratio (to go with more fuel. More fuel needs more air.) and voila! She runs.
I would take a serious look at your carburetor and tuning. You may have a stuck needle valve, poor float or you may be tuned to run well with the cowl off (more air) and then the cowl is put back on, air restriction and flooding.
Just thoughts.
J
