carlosburitica
- Aug 12, 2010
- 24
I recently got a 1984 bayliner 2110. It came with a 125hp force and need to replace the prop that is damaged. According to the seller this was the original prop that came with the boat.
This is what I can read on the prop
This is what the engine says.
And found this info.
According to that the model I have is a FPS529 but with a 16 pitch not with a 15 plus is for a smaller size boat. Been searching and don't find much info about the correct prop
Any help is aprecieted as well as where can I get a prop for it.
Thank you.
Thank you.
