When you buy a set of the Boyesen reeds for your motor, you get enough reeds to replace all of the original ones.
"Pulled top piston out and attempted to take some measurements and came up with 3.378 for the cylinder, not sure how accurate my measurements were. I inspected the cylinder pretty well and didn't find any noticeable scores When taking out the reeds I found two with corner chips and one broken. How many boysen reeds do I need to replace both reed blocks? I think the broken reeds might have been the cause of my idle issues. Right now I'm contemplating honing the top cylinder and installing new rings, replacing reeds, head gasket, and hoping for the best."
I would pretty much agree with your plan, if the cylinders look like the pistons.
