Jiggz,
When I open the dash panels i saw the previous owner had the kill switch wired wrong. One leg of the kill switch was wired to the M terminal with the white wire and the other leg of the kill switch was wired to the green wire on the choke terminal. The boat ran like this with both cylinders firing and the choke worked also. The kill switch would not kill the motor when pulled. it would bog down a little but the motor would not die.
-That is correct with the kill switch (KS) wired wrong it will not kill the motor when activated. The correct wiring of the kill switch is to be in parallel with the two M contacts. The ignition switch in normal off position, the M contacts shorts together killing the engine by shunting the CD-coil modules.
I disconnected both brown wires that go from the coils to the terminal block. I turned the key to the on position, there are 2 wires coming from the kill switch both of them white one connected to the M terminal with the white wire the other connected to the M terminal with the blue wire. There is continuity in this configuration.
- This is not normal. With the ignition switch in ON position, there should be no continuity assuming the KS is not activated (man overboard) meaning the pin is in place. There is continuity but you never mentioned if the kill switch is activated or reset.
With the kill switch connected and the lanyard removed (like a man overboard), there is no continuity.
- This is not normal! With the kill switch activated (man overboard) there should be continuity. With continuity the engine shuts down everytime either from the ignition switch being turned to OFF position or the KS being activated (man overboard)
With the wires from the kill switch removed there is no continuity between the M terminal with the blue and white wires from the harness connected to the switch and the switch on.
- This is normal indicating the ignition switch is properly working.
With the blue and white wires removed from the switch, the M terminals there is no continuity.
- Again indicating the ignition is working properly. Assuming it is in ON position.
I don't know if this matters, with the switch in the off position, there is continuity between the M terminals.
-Again, this is normal for a properly working switch.
I did some testing on the kill switch disconnected from the ignition switch. With the lanyard in place and the button pushed in there is continuity between the two legs of the switch. With the lanyard removed (man overboard situation) there is no continuity between the two legs.
-Try reconnecting the brown wires in the engine terminal board and all the rest of the wiring correctly except for the kill switch. Keep both wires from the KS disconnected. Try running the motor again and post your results.
Jerry, this boat doesn't have a tach. Wished it did though.
