jerryjerry05
- May 7, 2008
- 17,926
Spray a quick shot of WD in each cylinder.
Dragging starter:: weak battery(even new can be bad) load test it. bad starter(even new can be bad) rebuild it.
Bad battery cables, bad connections, bad solenoid, gears/ bearings in the lower unit seizing. Remove and see if that makes a difference?
