I need to replace the voltage regulator on my 1994 Force 150HP outboard; luckily the motor never stranded me in the middle of the lake, but while changing spark plugs I found it's pretty badly burned, and surely will fail soon.
Can someone on this forum verify the correct part number I need, and/or a source for that voltage regulator? Does a burned out VR indicate I should also replace something else? Thanks in advance....
