SoCalTrophy
- Mar 18, 2017
- 7
I have a 95 Force 120 and wanted to check the prop seal and decided to remove the propeller housing and gear case. Removed 2 bolts holding carriage and slid out gears. noticed i was missing a Big O ring but i found that the cam fill out and there was bearings inside the housing. i found 2 bearings. I read that these are detent balls that prevent the dog clutch from slipping. I HAVE NO IDEA how to get these back in. Can you someone Explain.
Here is the parts diagram, #45 is what came out, i slid the cone metal piece that sits on top of the spring but cant find out where to put the bearings back Someone please help.(tried uploading a pic but i must be a newbie, keep getting a error)
Thanks in advance to everyone
