brokenwrist
- Feb 17, 2016
- 73
ok guys here comes another chrysler question. Before the question let me tell you about what I went through in finding my hidden problem. Last year I bought my boat and got the outboard running mostly going ok. Got it out on the lake last year a couple times, made the engine work a little bit, but performance really wasn't where it should have been, but the first time it was out my dad and I noticed what sounded like a grinding sound, never figured out what it was until today when I pulled my prop bearing cage to replace the two orings and prop shaft seal. I discovered after the cage was out that the bearing had completely failed and come apart, the race in the cage is crooked, where the race seats is bent, the prop shaft is scored to hell. So I now believe what the noise we were hearing was the bearing failing and coming apart. Apparently who ever worked on my outboard years before me, had 0 clue what they were doing and screwed everything up. Some parts are hard to come by. Now back to my question. I found on ebay a complete 1978 75hp lower unit. Will this lower unit work on my 79 70hp, or do I need to find one for a '79 70? Could I put a force one piece 70hp lower on? For these engines what are the interchanges? I've searched a few different areas and couldn't find a clear answer or chart.
