Glastron Boater
- Jan 22, 2017
- 97
Hey guys, I have a 87 Force 125 that the carbs seem to leak out gas. Is this normal when Tilted/Trimmed?
I don't think they leak with the engine running or when the outboard is straight, Is it normal to have gas/oil because of the angle it gets?
If I go to rebuild, Is there anything special that needs to be done?
What Kit number would I need? Boat runs fine, just leaks out of the front/intake hole. I looked on iBoats, they have too many selections I don't know which I need.
How do you fine tune the carbs together?
Should I get a fuel filter?
Please share Part Numbers or Links to products I will need.
Thanks.
Thanks.
