Mikhail2400
- Feb 1, 2017
- 2
I recently inherited a Force 85 model # 856x8a and i know absolutely nothing about this motor. Its been setting up for a minimum of 12-18 years. I dont know if it ran when it was parked or any thing else i need to know. It has had the motor cover on the whole time but it has sat out in the weather mounted on a fiberglass bass boat. From what ive read i believe it was made in or near 1988 and being that old i guess its safe to assume its a 2 stroke.
What i would like to know; What reputation does this motor in general have. What i mean is are they considered prone to lots of problems or are they difficult to keep in tune? Or are they considered to be one of those rare motors which seem to have left the factory perfectly engineered and keep ticking no matter how hard you run them?
The other thing i need to know is; How should i go about getting this motor ready to fire up? Im sure i will most likely need to replace the fuel lines and do a visual check for bad wiring or other obvious problems. Other than draining all the fluids and replacing them can anyone think of some other vital step i should do before turning this motor over?
Thank you for your time and expertise on this subject. Sincerely Mikhail2400
