dropbear68
- Jan 21, 2013
- 199
Ive gathered a few Chryslers up now 2x75s both late 70 s and a mid 70s 70 that threw a rod, I want to build up a 75 , my first silly question is when did Force copys of Chryslers cease to be Chryslers, up to when can I use Force bits in a rebuild, So for starters if my 75 needs a bore ill have it done and get new pistons, i want to have the crank balanced, if necessary reground to suit o/s rollers, ill linish it in the lathe and polish, do I do your porting trick? I heard you can mess with the exhaust plate in some way, ill rekit the carbys, what do the Forces use in way of ignition, powerpack or CDI, the gearbox will be re bearinged, any advantage using the 140 HP prop ? Water pump will be done Im going to fit a tell tail, water pressure gauge and get the over heat buzzer going, I dont want ball bitingly quick I want reliable
Are new rod bolts available now way ill reuse old ones, ill do some work on the rods wiegh them up and trim so there all the same de burr grind the seams flush, dont want a rod letting go, ill do the thermostat new belt for dizzy, new leads cap plugs etc,
Any head tricks to try? Would new head bolts be available maybe Force.
I have picked up a 95 Force 150 thats chucked a piston comes with second block and crank getting a new piston be easy enough?
