NJGamefisher
- Jan 10, 2017
- 14
I recently acquired a 1986 Force 15 that has been basement kept for the last 10 years. My grandfather put less than 100 hours on the motor and took impeccable care of it. I am purchasing a 16 foot aluminum boat for it and I contacted the local marina to see if they should go over it before I start the engine and use it. I was told to run the motor and see if it runs good first. He said that parts are impossible to get for the motor and I should just run it as long as it seems good.
My question is that is it really impossible to get servicing parts for the motor. I would like to replace seals, impeller and gaskets in the lower and have the carb rebuilt. Is it really impossible to get these parts or is it that the marina mechanic just doens't want to mess with an old motor. It really is in great shape, I just think after sitting that long it should be gone through.
