amcervantes
- Dec 4, 2016
- 18
Ok guys I need some help I took my boat out yesterday and I couldnt get the boat over 8 mph. I found that the spark plug wire boots and springs were bad and arcing out of the boot. Replaced boots and springs and spark plugs. Put the muffs on and boat ran awsome in gear and at idle. When I took the boat out today it would not run faster than 8 mph. Every time I would go wot it would just bog down and die. When I would put it in reverse it would run faster than in forward got home put the muffs on and it would run wot. It doesnt like the load. Any suggestions? Im going to do a spark test for the coils and also clean the carbs. Anyone else have had the same problem?
