Hello all,
I have this problem in my outboard, It was running good during summer, then at the end of summer last time we use the boat sometimes it was working like missing power on one cylinder, I change Spark plugs, check all fuel lines, then I didn?t use the boat.
Yesterday I try to start the motor with no luck, I check spark and it was missing spark on cylinder 1, cylinder 2 and 3 good spark. My first thought that it was the coil, I swap coils and then I miss spark on cylinder 2 and spark on cylinder 1, so coils are good. My next thought lead me to the power Pack 1 for cylinder 1 and 2.
I read some posts they said you can swap packs, I need some help to do this, do I have just to change connectors and coils?
I check also resistance for trigger and stator, which give me the next numbers
Blue to Yellow 720 Ohms
Blue to Ground Open
Yellow to ground Open
Orange to White/green 52 Ohms
Red to white/green 52 Ohms
I ran a test without rectifier with no luck, also disconnecting the white cables from pack.
I think is the pack number 1 with the problem, but I want to makes sure wit you guys before to buy the part since it is expensive
Any other test?
Blue to Ground Open
Any other test?
