I have a 1987 force 125 outboard the model and serial number have worn off the data plate. The question I have is I replaced my starter and now it appears that I have no spark. I have no dva meter to test stator. But I did check the resistance on the leads. My number 1 and 2 wires show infinite resistance yet my 3 an 4 show 750ohms then my two wires for charging show very low resistance. The motor was running fine before I change stater. I disconnected rectifier as well as the two white wires for the kill switch off of the terminal post. Is there anything I could be missing or does it appear as the stator needs replaced. It's a prestolite ignition with the black coil and ignition packs all with terminal block connections. Any help would be greatly appreciated.
