My 1995 Sport Jet with a 120hp Force has white plastic carburetor floats,so the "tab" is not adjustable to set the float level. Invert the carb and the float is not horizontal to the casting body like the manual calls for. All info I have says to bent the tab, and that's easy with metal floats.It would appear my fuel level will be slightly low causing lean running. Any advice will be helpful. I bought this boat 2 months ago for a winter project, looks great otherwise........Bernie
