Chryslerman123
- Nov 18, 2016
- 87
So, finally got my 1971 chrysler 20hp outboard running. Ran it in a 55 gallon barrel. When I first start it, water sprays out indicator perfectly when idling. Once i give it a little throttle and go back to idle, there is very, very little water coming out of the indicator.it looks like no water is coming out at all sometimes. I have never ran it for more than two minutes at a time because I'm scared it's not getting enough water. If you let it set for a while and then start it up, it is the same thing every time. The impeller has been sitting in it unused for 25-30 years but was new at the time. It is fairly flexible with no cracks or anything. The only thing is that it has taken a "set". I pulled the lower unit after running it and checked the impeller and it is in the same condition it was before I ran it- seems like nothing is wrong with it, or, is there another problem?
