DunbarLtd
- Nov 8, 2016
- 335
I did the lync and sync that is at the top of this forum to the T and I can get the carby flies to open fully all together without the cable connected. I adjusted the towershaft link rod correctly onto the cam. The cam is not bent. The roller has been adjusted out so that the line on the cam is tangent to the roller. I think Ive covered everything i need to.
But when I go to connect the cable while in neutral and go to the controls and give it WOT i cannot for the life of me set it up to get the carby flies to open fully. They get about 75-80% and thats it. This boat originally had the US Marine control box that was broken when i bought the boat. I purchased a Teleflex SL3 controller and have it hooked up in the proper holes.
Is there something that can be worn out on the engine side i cant see that causes this? I even spun the quick connect in (towards bow of boat) a little so i had to pull on it to get it on the ball stud and still only get 3/4 WOT. Not sure whats going on but its very frustrating to say the least.
Also Ive purchased new cables so im not too sure they are stretched out.
Any help is definitely appreciated.
Edit: Ive included a link to the manual for the control box if that helps. Its a side mount (starboard).
Also I am using 33c cables with threaded ends and quick disconnects.
http://www.nauticassistance.com/Cms_...r%20manual.pdf
