NeilDaCosta
- Mar 13, 2014
- 18
My engine was running, now won't start. When key is turned it the starter works, but the engine itself won't start. Any ideas of what to look at next?
Compression is good
Spark is good
Timed/adjusted according to Frank's tutorial. I even used the voltmeter test in the manual to test the timing.
Carbs are clean and floats are adjusted accordingly
And yes, there is gas in the tank!
Thanks.
Compression is good
Spark is good
Thanks.
