Shortly after launching the boat I always notice a small amount of fuel in the water. Any thoughts on where this could be coming from and why? Un burned fuel in exhaust? Is this normal? Its not a lot but enough for me to notice.
Also,
When i mix my fuel i use the standard 50:1 mix. I also was told to throw in the proportionate amount of "Lead Substitute". Who else uses this and is it totally needed on this model motor? Just makes things more complicated at the gas pump for me.
Thanks!
Also,
Thanks!
