I been fighting this problem for a couple of years. If I accelerate slowly, The engine will run good and then die at around 2100 rpm, If I go Full throttle, Most of the time it will take off with lots of power and run great above 2300 rpm. I replaced the charge coils, rebuilt the carburetors, Cleaned the fuel recovery system, substituted CDI's, Checked spark at idle, rebuilt the fuel pump, the trigger coils resistance is within tolerance, I even tried adding an electric fuel pump both inline with existing fuel pump and also feeding the carburetors directly in case it was a fuel delivery problem. It seems to get worse after the motor heats up after a while. This problem only shows up under load and not while using muffs. I'm 70 miles from nearest lake which makes troubleshooting a real pain. Also compression checked good. Would appreciate your thoughts on this
Joe
Joe
