I have an 1989 35hp electric start force model #357F9B. I have replaced the drive shaft, along with the water pump. At the top of the shaft a brass ring is pressed from the factory there is a rubber boot type seal that sits down into the brass ring
When inserted up into the flywheel it seals the hole the shaft goes through. When the lower unit is completely reassembled to the power head the prop will not turn in neutral, I slightly loosen the bolts connecting the lower unit to the power head and the prop turns freely. I'm not sure if the rubber seal boot has anything to do with the pressure on the driveshaft or not, but now to remove the lower unit back off you need to use a tie down ratchet type strap to break it free because that rubber boot seal seats up into the hole the shaft goes through to connect to the flywheel. I've gotten it out once already to make sure I'm seated correctly at the water pump location into the lower gears and just would hate to have to pull it again. If anyone can give me some input on this lower unit I would appreciate your help. Thanks, Mike V.
