I have been reading the Threads but have not found one directly related to my specific HP. I'm not sure if it makes a difference, because I'm new to outboard motors so please bare with me. I just bought a boat and was out on the water when I went to start it and the battery would not turn it over. I flagged someone down for a jump and after charging the battery for a minute through jumper cables it fired right up. I brought it home and started my research. Everything points to the rectifier or stator. I ordered a new rectifier and installed, but upon doing so, I tightened the ground to much and broke the ground lug. Out of frustration I went ahead and fired up the engine. To my surprise the motor was idling beautiful which it never did before. It actually stayed running for like 5 minutes without stalling. I have been nervous on the water because whenever I pull into the dock it always would stall when I'm going to put it in reverse to stop and tie off. I was told that because its a 2 stroke they don't really like to idle and being I was new to boating, like a dummy I believed them. Back to the issue though. Being I broke the rectifier ground I had someone hold the ground wire to the lug that broke off. I ran a couple of test but not sure if they're accurate. Anyway it still wasn't charging, but was idling great. I noticed the RPM gauge wasn't working anymore either. I ordered the new rectifier and a stator just in case. If I install the new rectifier (without breaking it) and it doesn't charge the battery, my next step is the stator. Correct? Also I can't find a tag that shows what exact engine I have. The only tag is a little white sticker that says 1201A90A. Can anyone help with this or point me to where it might be inscribed in the engine? All help will be greatly appreciated.
