I am having some issue and need some help.... I have a 1973 Chrysler Outboard 55 HP with the model number being 559HF.
the issue I am having is this
Start the motor up runs great with a little choke motor warms up runs for about 3-5 Minutes then boggs itself out in that time
after the motor shuts down I try to restart it with choke with no choke nothing happens wont start then I open my float bowl let it drain completely empty...
then try to start again it starts right up and runs great for the 3-5 minutes and slowly boggs it self out in the middle of that time if I try to kick it in gear it boggs it self
down within seconds but if i leave it in neutral then it will run for the full 3-5 Minutes
any suggestions are appreciated trying to get this thing running in time for early goose season!!!
