my engine has never ran up to rpm since replacing a 9 amp bad open winding stator with a 16 amp stator (used). It has been running worse and worse until now when it will no longer start at all. the engine is a 1208X92c s/n 24809. the replacement stator is a 398-9710-31. the red-red/white coil is fine at 97 ohms but the blue-blue/white is 6100 (spec is 3500+/-. would this high resistance be causing my problem? The stator for this engine with bolt in magnets spec is 7k ohmns so i'm thinking that the stator may not be the issue. the trigger is right in spec for ohms (880) but I question if my switchbox is the problem. I have had no power, just barely brought the boat up on plane with only me in the boat. It would run for a short while then it would start backing off the boat would drop off of plane and I would get right back to the dock in fear of it dying completely. It would die when brought down to an idle. Just cleaned up both carbs (two days soaking in laquer thinner). tried new gas, no change. I have spark on all four plugs. new plugs. Compression is a bit low at 145 psi but that is not bad. any thoughts? this boat has been in the family from when it was new. the engine has never given any problem at all. The stator or switch box? or something else? Help very much appreciated.
