I have a Force 150hp 91 j series outboard with thunderbolt ignition (not prestolite)...one switch box, 5 coils. I recently replaced the flywheel and stator because the magnets disintegrated. Ran great for 5 d. Then all of the sudden it began immed dying (w/o sputtering or faltering) when I advance the throttle. Idles great. When I advance throttle past a certain point it doesn't sputter at all like starving for fuel or missing on a few cylinders, it just cut off/dead. Starts right back up in neutral. Any thoughts? Fuel seems unlikely (but I changed all filters and re-inspected lines anyway), Candidates would seem to be...converter box, switch box, or trigger assembly. Trigger assembly looks fine but the problem "seems" to be about when the timing advances and it rotates. Thanks for your help
